Assembling Z-Top got me Stuck
Hello,
I got to the step where I'm supposed to mount the Z-Top and I realized something seems uneven because the Z-tops seem to be difficult to mount to the frame without forcing them. I look for the reason and then I realize that when I place the X-Axis on the lead screws, without screwing anything in, the left side is slightly lower than the right side. I have pictures below:
What could be the reason for this? I appreciate the help. I unmounted and mounted back the Z-Motors, but it's the same result.
Re: Assembling Z-Top got me Stuck
Hi Maxwell,
screw the Z leadscrews so that the X ends go down far enough to fit your Z ends,
X axis levelling is dealt with, later in the build sequence!
https://www.prusa3d.com/new-user-mk3/
it's about 3:29 on the video
Joan
Joan
Thanks a lot, Joan. I've moved on.
