Assembled kit Z "Calibration failed!"
Vern
 Vern
(@vern)
I bought an assembled (by prusa) kit and when I run the z calibration wizard I'm getting the error when measuring reference point 1 of 9.
"Calibration failed! Check the axes and run again."
I'm wondering where to start here, seems unusual for this to fail right out the box?
Respondido : 21/07/2019 2:23 pm
Vern
 Vern
(@vern)
RE: Assembled kit Z "Calibration failed!"
Solved, I followed the instructions for the self build setup. Reran selftest, recalibrated XYZ. Doing a test print now, I believe it's working.
Respondido : 21/07/2019 3:24 pm
Curious: what did you change that allowed it to work?
Respondido : 21/07/2019 5:43 pm
Vern
 Vern
(@vern)
To be honest I'm not entirely sure. I did XYZ calibration, and when it reached the top of the y axis the motors started making a weird noise, it almost looked as if wasn't entirely level. I panicked and hit the power button since the motors were making that noise. When I turned it back and reran the calibration it was fine. I've printed a few things, all is well now. I guess it's reasonable that a package going from the Czech Republic to Vermont in the US can take a lot of bumps and it's reasonable that you'd need to recalibrate.
I have to say I also had to do several tweaks to the first layer calibration, but the printer is amazing for that. I'm coming from a Makerbot i3v  that is years old https://drive.google.com/file/d/0B80A_woXoRWdMkhVUWs5WXVyZW8/view that was given to me and it's incredible to see all the quality of life improvements this printer has. So far so good!
Esta publicación ha sido modificada el hace 7 years por Vern
Respondido : 21/07/2019 7:47 pm
