Are those two optional X-axis upgrade parts recommended (i3MK3S to i3MK3S+ upgrade kit)
Hi, I know it is optional and the old ones will still work with the new components for the MK3S+. How many of you upgraded the x-end-idler.stl and x-end-motor.stl? Is it better to upgrade?
Napsal : 04/03/2021 2:24 am
RE: Are those two optional X-axis upgrade parts recommended (i3MK3S to i3MK3S+ upgrade kit)
Hello,
I've not upgraded to MK3S+ yet but I will. As I feel that adjusting tension on the X belt should be easier with the new X axis parts, I will too and it will also be an opportunity to clean and regrease the bearings of this axis.
MK3s Stock, PS2.3, Fusion360, Debian, Windows 10.
Napsal : 04/03/2021 8:54 am
1 lidem se líbí
I did the upgrade also for a color change of the printer. Most parts are white now.
But I liked the new x end parts. The belt tensioning works better and has a little more range.
Napsal : 04/03/2021 9:03 am
1 lidem se líbí
