any idea why the xyz cube is printing this way?
Crunch
(@crunch)
fw 3.2.0.rc2 any idea why the xyz cube is printing this way? belts are correct tension i am scratching my head about the large line on the right corner of the x axes and ringing both in the x and y axes
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Publié : 04/05/2018 5:59 am
thrawn86
(@thrawn86)
Re: any idea why the xyz cube is printing this way?
its not that bad, really. I'm guessing thats at .1. I would try .2 for troubleshooting purposes.
ghosting: whats your accel and jerk? lower them. looks worse considering its black filament + flash
sag: cooling issue, take your pick of different nozzles. stock sucks. but
seam: using wipe at lower layer heights does that, in my experience.
Publié : 05/05/2018 3:28 am
nenad.b
(@nenad-b)
It is slicer setting issue. More precisly retraction settings. At the retraction point (vertical line) there is too much retraction or related with retaction options (wipe on retraction etc.).
Check also linear advance setting in your script.
Whatever slicer you are using try standard retraction settings and do not go faster then 60ms for perimeter lines. To make it even simplier, I woud desacitvate linear advance too.
Once ok, take care of ringing. Keep in mind that will be always some ringing. With prusa you do not touch with firmware, so try to print slower.
Publié : 01/06/2018 3:13 pm
