Another noob with wizard 'Calibration failed!, check the axes and run again'
SSN613
(@ssn613)
I've read through numerous posts on this issue.  Build MK3Cs+, first part of wizard checks pass, phase 2 (ensure steel sheet is not installed, place paper on hotbed), fails almost immediately as Z goes to bottom.  I checked for twist on frame, movement on all the axes, cable management not binding or hitting, pinda operating and correct level (even purpose under and over), nothing changes the behavior.   I flashed down to 3.9.3 firmware on a lark, no change.  Of course the error is not helpful. Suggestions?  Manual method to set cal and move on? 🙂
-Eric
Videos (short) at:  Part 1 video of calibration wizard:  2 video of calibration wizard:
Napsal : 06/11/2021 2:31 pm
BogdanH
(@bogdanh)
RE: Another noob with wizard 'Calibration failed!, check the axes and run again'
Today I assembled MK3S+ and first upgraded to firmware v3.10.1-RC1 (beta). And it failed at the same point as you describe. I have checked belts, pulleys, SuperPINDA, etc. again and again, but nothing helped -as you say, advice "check your axes" isn't really helpful.
Anyway, then I installed latest official firmware (3.10.0) and without making any changes, succeeded with whole calibration on first attempt. What can I say, I don't really have any usable advice... hope you will solve the trouble.
[Mini+] [MK3S+BEAR]
Napsal : 06/11/2021 8:58 pm
Contact support via chat.  They can walk you through what to do.  You paid for it so I would use it.
Napsal : 07/11/2021 2:49 pm
SSN613
(@ssn613)
I would, but can’t find chat support, only email, which was never responded to.   In any case, after going down a firmware version and then back up, it works.  Odd.  Hopefully no more issues.
Napsal : 08/11/2021 12:38 am
Posted by: @ssn613
Login in to the shop and it will appear:
Napsal : 08/11/2021 1:49 am
