After 6 hours, print curls and crashes
ayroblu
(@ayroblu)
Hi All!
I'm new to the whole 3D printing process, I was trying to print a little holder I found on thingiverse using their exact recommended prusa settings. However about 6 hours in to the print, if has this section that curls up and causes a crash and the print to fail.
I'm not really sure what to do here, I have no clue what's causing this, so any help would be appreciated!
Opublikowany : 21/11/2020 1:42 pm
RH_Dreambox
(@rh_dreambox)
RE: After 6 hours, print curls and crashes
Hi ayroblu
If you show a picture of the underside of the detail (the first layer) then we can see what you can do.
This is usually due to a too high Z level and / or a poorly cleaned bed.
Opublikowany : 21/11/2020 2:36 pm
ayroblu
(@ayroblu)
Hey sure,
Let me know if that helps?
Opublikowany : 21/11/2020 2:42 pm
RH_Dreambox
(@rh_dreambox)
Sorry, there are no picture to look at.
Opublikowany : 21/11/2020 3:54 pm
ayroblu
(@ayroblu)
Oh that's horrible, the forum doesn't have it's own auto uploader, let's see if this works
IMG-1619
IMG-1621
Opublikowany : 21/11/2020 4:06 pm
