Adjusting the height of the PINDA sensor
Bryan34
(@bryan34)
I've just finished the kit and I can't get the PINDA sensor to move for adjustment. As it happens, the level of it is about .17 mm higher than dead flat on a cable tie. That's the thickness of two sheets of paper. It seems to me that it should be close enough to proceed. Does anyone know?
Veröffentlicht : 26/08/2021 8:38 pm
Dan Rogers
(@dan-rogers)
umm
The pinda sensor moves up and down - it is held by a slip collar that is tightened with a screw.   Loosen the screw, loosens the slip collar, move the sensor with your hand.  If it won't budge, loosen the screw...  Repeat.
Veröffentlicht : 27/08/2021 5:56 am
Bryan34
(@bryan34)
Resolution
I know how it works. I had removed the screw entirely, and it still wouldn't budge. I inserted a screwdriver into the slot from the top to pry open the clamp, and it wouldn't budge. Finally I inserted a larger screwdriver from the back side to pry open the clamp top to bottom, and the PINDA moved.
Veröffentlicht : 27/08/2021 5:58 pm
Dan Rogers
(@dan-rogers)
Call that one "the pursuader"
Your screwdriver has earned an achievement.  It may now be forevermore known as "the pursuader".
Veröffentlicht : 28/08/2021 3:39 am
Bryan34
(@bryan34)
Prusuader
Don’t you mean “the Prusuader”?
Veröffentlicht : 28/08/2021 3:58 am
