Adding back plate
gatonini@zoominternet.net
(@gatoninizoominternet-net)
Adding back plate
Every time I try to put the backplate on my mk3s extruder it causes a bind and the extruder wont slid on the rails any ideas ?
Respondido : 16/09/2019 7:29 pm
RE: Adding back plate
Don't tighten the screws as much.  This is a "normal" behavior with the MK3S ... apparently worse if you printed it yourself.
There are two modes though: one is the clamp force can compress the bearings so they drag on the rods - similar to the U-bolt issue on Y.  But another possible mechanism is the distance between top and bottom bearings being off - and this is from printing on a printer with a calibration problem.
Esta publicación ha sido modificada el hace 7 years por --
Respondido : 17/09/2019 3:14 am
Mojo
 Mojo
(@mojo)
Can you post a picture of your extruder without the backplate?
Respondido : 18/09/2019 11:04 am
Please ignore me I was a dumbass and too long screws and they were in the belt channel pushing the belt out !
Respondido : 18/09/2019 2:15 pm
Mojo
 Mojo
(@mojo)
I had a case were the Nylon Filament Cable guide went to the belt area instead of the hole for it and blocked the belt. When I figured that out I fellt like a dumbass not taking enough care in assembly^^
Respondido : 19/09/2019 2:19 pm
