problema al imprimir
Alejandro
(@alejandro-2)
Problema al iniciar impresion , tengo un problema cuando quiero iniciar una impresion , la cabeza de impresion hace bien el conteo de los 9 puntos y al irse al iniciar la impresion va he baja hasta la cama y despues se levanta y se va al lado derecho de la impresora  se queda pitando y dice que pulse el dial para descargar el filamento , y tengo que apagarla o reiniciarla para dejarla bien como al inicio , alguien me puede ayudar por favor , muchas gracias
Alejandro Gonzalez 😫
Posted : 26/12/2020 2:41 pm
RE: problema al imprimir
Hi Alejndro,
try turning the filament sensor off and try again...
is your printer mk3S  or mk3S+
there is a spacer on Thingiverse which may help with your filament sensor
https://www.thingiverse.com/thing:4006603
Posted : 26/12/2020 3:55 pm
Alejandro
(@alejandro-2)
😀 Hello joantabb I did what you tell me in your post but it did not work for me, it is still the same, I have the prusa i3 mk3 without the S, I hope you can help me I would appreciate it very much ok? thanks Alejandro Gonzalez
Posted : 26/12/2020 4:45 pm
Alejandro
(@alejandro-2)
@joantabb
I can't print now as the printer is not working for me until that error is fixed, but thanks for the file
Posted : 26/12/2020 4:48 pm
Have you tried turning the filament sensor off. to stop it trying to change filament erroneously?
this should enable you to print the part!
Posted : 26/12/2020 5:14 pm
Alejandro
(@alejandro-2)
I have tried to print without the filament sensor and without filament and it keeps showing me the same error, I don't know how to put videos here I would send you one so you could see the error and so you could give me your opinion, thanks again, you are very kind
Posted : 26/12/2020 6:39 pm
Kalimero - Jan Fiala
(@kalimero-jan-fiala)
Click on Add Media and next menu will appear.
Nejsem zaměstnancem Prusa Research.
Posted : 27/12/2020 8:04 am
Maxavriemma
(@maxavriemma)
Hi Joan,
I am going to comment that I have the Prusa MK3 S+ kit, I was going crazy looking for a solution and reading the manual to see what could have gone wrong and look for the error.Your solution worked for me, by deactivating the filament sensor. Is this a printer error?
Greetings Edward
Posted : 26/02/2022 4:58 pm
Hi Edward,
I have not tried the Mk3S+ extruder, so I have no direct experience,
On the Mk3S, there was an issue where the filament sensor was over sensitive, and putting a thin spacer underneath the mounting screw hole in the filament Sensor PCB, improved t he response immensely
other possible causes are
filament particles stopping the ball bearing moving freely,
the filament sensor lever pivot screw being a little too tight,
the Filament censor PCB fixing screw being a little loose,
loose connectors,
faulty sensor wire
I fitted a 5 volt LED to mine to give immediate status indication
and the MMU2s version
Posted : 26/02/2022 6:27 pm
Maxavriemma
(@maxavriemma)
Hi Joan,
Perfect, I'm going to be testing, I'm going to download the file you left in the thingiverse link and when I add that little modification I'll be commenting shortly.
Greetings Edward
Posted : 26/02/2022 6:46 pm
Make sure it is a 5Volt LED...
Posted : 26/02/2022 7:04 pm
