dimensioni stampante
ciao a tutti volevo chiedere se gentilmente potreste darmi le dimensioni della stampante ,non quelle di stampa ma effettivamente quanto ingombra tutta la stampante.
grazie
Best Answer by Matteo Cristini:
Dal sito:
- An assembled i3 (MK2/3) printer itself has 16.5 × 16.5 × 15 inches / 420 × 420 × 380 mm and 7 kg
- MK3/S print area: 9.8 × 8.2 × 8.2 inches / 250 × 210 × 210 mm
Keep in mind that the mini and all i3 printers need some more space when in use. Especially in front of and behind them, as the heatbed is moving outside their foot-print. Count with 19.7 × 21.5 × 21.5 inches / 500 × 550 × 450 mm (400 × 450 × 450 mm for the Mini), without the spool or MMU.
If you are building an enclosure, you can add even more space in every direction, for better access and manipulation. For the MMU, add 150 mm / 6 in, in height and think about where to put the 5 spools (behind the printer or above).
Veröffentlicht : 27/02/2020 12:23 am
RE: dimensioni stampante
Dal sito:
Veröffentlicht : 17/03/2020 8:30 am
@matteo-cristini
Grazie
Veröffentlicht : 17/03/2020 2:54 pm
