[Solved] Buying replacement thermistor for i3 mk3s
John
 John
(@john-35)
Could anyone please provide a link to a replacement hot end thermistor? my wire broke and now i have a constant min temp error. I know i could soldered it but i would just as soon replace it with an original or upgraded part. Thank You
Posted : 23/11/2019 2:39 am
RE: Buying replacement thermistor for i3 mk3s
you can order directly from Prusa. Log into the estore and you'll see the parts. You should get a 5-10% discount if you purchased a Mk3 previously You didn't mention where you are located, but you can also order parts from several US-based resellers including PrintedSolid.
Posted : 23/11/2019 3:25 am
John
 John
(@john-35)
@bobstro
Thank you!
Posted : 23/11/2019 11:40 am
Edwin
(@edwin)
Also have a problem. Thermistor pulled out of heatbed, and needs to be replaced.  I register here in community, also log in prusa store, but i did not see item for sale.  In Manual for replacement is this link - but  "Sorry, only registered i3 printer owners can access this product" is message in page after opening. I am logged in page by this community account.  Should i somewhere register my assembled printer?
Posted : 26/03/2020 11:11 am
Zoltan
(@zoltan-d-2)
Member Moderator
@edwin
Where/ how did you by your printer?
Register and then login here https://shop.prusa3d.com/en
Posted : 28/03/2020 6:00 pm
Edwin
(@edwin)
@zoltan
buyed from Alza. was 2 minutes from home and on warehouse with same price.  On Page provided i am already logged. Maybe fact, that i dont have any orders for printer does not allow me to buy this kind of stuffs.  I try support.
Posted : 28/03/2020 6:05 pm
Zoltan
(@zoltan-d-2)
Member Moderator
From eshop start the chat with support, I am sure thay will help you
Posted : 28/03/2020 6:14 pm
