Nozzle 0,15 mm
Javi
 Javi
(@javi)
Nozzle 0,15 mm
Hello, has anyone printed with a 0.15 nozzle?What are the correct parameters?Thank you so much.
Publié : 30/05/2023 3:34 pm
joenna234
(@joenna234)
Membre
RE: Nozzle 0,15 mm
As i know around 50-70% of the nozzle diameter (0.075-0.105mm). A smaller layer height allows for finer details. Lower than usual, as the smaller nozzle size requires less heat. Start with the manufacturer's recommended temperature for the filament and adjust if needed.Slower than usual to ensure precise filament deposition. Start with a speed of around 30-40 mm/s and adjust as necessary.
Publié : 05/07/2023 11:20 am
Javi
 Javi
(@javi)
RE: Nozzle 0,15 mm
Muchas gracias juan234 por su respuesta....
Publié : 14/07/2023 4:01 pm
cet
 cet
(@cet)
RE: Nozzle 0,15 mm
J’utilise les données, sans rien changer, de la buse 0.25 et elle s’imprime bien.
Publié : 15/07/2023 4:56 pm
Javi
 Javi
(@javi)
RE: Nozzle 0,15 mm
Muy interesante cet, probare sus amables consejos, muchas gracias por la ayuda.
Publié : 15/07/2023 6:25 pm
jasanda45
(@jasanda45)
Membre
RE: Nozzle 0,15 mm
The optimal printing temperature depends on the type of filament you are using. Refer to the manufacturer's guidelines for the specific filament. Generally, lower temperatures are recommended to prevent overheating and oozing. You might start with a temperature 5-10°C lower than the manufacturer's recommended temperature for your filament.
Publié : 14/08/2023 7:20 am
