Print Destruction
Hello, I am trying to print the structures below, but I experienced major failure as seen below
This print is at a 0.3 mm layer height, which is necessary for research reasons. Infill is set to 100%, and the print temperature is 230°C with E-sun PLA+ & base temp of 60°C. The semi circles on the sides are to prevent warping
Any help would be greatly appreciated,
Thank you:)
Opublikowany : 14/04/2025 11:13 pm
