How do you print three separate color from three different file?
JMH714
(@jmh714-2)
I'm really new to color printing now and I'm trying to figure out how to print colors with single model with separated individual colors as for example: https://www.printables.com/model/569280-mk4-pg-case-fusion360-step-files - the files have separated group of parts of the model. I tried to "assemble" it on PrusaSlicer and I don't seems I was able to line up perfectly.
Is there a way to line it up perfectly or I'm doing it wrong?
Thank you.
Best Answer by Diem:
In your CAD just create the parts, in place, leaving room for each other - and export them - you then have three seperate but related files.
Select all three in one go - import them all at the same time - on arrival slicer will ask if they are parts of the same object, yes they are - and they will be loaded together in place.
Attached is a sample .zip containing 3 STL files - if loaded as above it becomes a 3 colour print.  If loaded individually they will fall to the print sheet and no longer work as a single print.
Postato : 31/10/2023 9:41 pm
I answered almost the same question earlier, see:
https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-how-do-i-print-this-printing-help/procedure-for-multi-color-printing/#post-681913
If you are attempting to print directly from a Mk3.n without MMU then these will be of interest.
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Postato : 01/11/2023 12:56 am
1 persone hanno apprezzato
JMH714
(@jmh714-2)
RE: How do you print three separate color from three different file?
Thank you and seems like I was too lazy to run search.
It's way over my head. Is there a detailed step by step instruction in Knowledge base or anywhere else?
What I'm using: MK3S+ with MMU3 and PrusaSlicer.
Postato : 01/11/2023 8:07 pm
Postato : 01/11/2023 10:47 pm
JMH714
(@jmh714-2)
This is interesting... So, if I downloaded a multi-color from Printable.com onto Fusion 360 (this is what I have) and put pieces together and then save it as zip. And then extract it onto PrusaSlicer and voilà, its ready to print. Is it correct?
Secondly, I don't realize the thread I created is in MK3.9/how do I print forum... I thought I created it in MMU3 forum, how embarrassing! 😭 😰 🤣
Postato : 03/11/2023 5:42 pm
JMH714
(@jmh714-2)
Updated.
I just played with it and now I get it. Thank you, Diem, for that! 👍 👍
Postato : 03/11/2023 6:07 pm
DJ
 DJ
(@dj-8)
Utenti
