Typo in Alha6 documentation regarding Klipper additions
Bernie.H
(@bernie-h)
I was teaaring my hair out trying to find out why my 3S+ was printing without filament, thought I had a blockage when I exported gcode via octprint. printer would go thru all steps apart from filament extrusion. I then export sliced gcode to SD card and all was well. Hmm.
Alpha5 did what it was supposed to do, so figured it was something that had changed in alpha6, and the big glaring addition was limited Klipper support, so I read that very carefully.
Thyere is a line detailing AUTOEMIT, talking about heating gcode............
So, my contention is that this should read AUTOOMIT, not EMIT !!
Thoughts
Publié : 04/04/2023 1:48 pm
RE: Typo in Alha6 documentation regarding Klipper additions
No you are incorrect.  The big complaint from the Klipper crowd is that before if you do not add specific heating lines to the start gcode PS would always add them.  They wanted that changing.  As there are also others besides Klipper that also have asked for that change in the past then there is the new tickbox.  This is so that it doesnt break existing profiles but the user has to make it OMIT the lines now by UN-ticking that box.
If you updated your standard MK3 profiles and that box wasn't ticked Automatically after the update then that is a bug and should be reported on github.  The operation of any of the standard profiles should not have altered because of the update.
Publié : 04/04/2023 2:58 pm
Bernie.H
(@bernie-h)
Thank you,
Somehow there is a conflict with Octoprint plug-ins. I don't know why but Octolapse caused the issue. Once I removed the plug-in, all worked aqs normal.
My mistake as I'd used it before
Publié : 05/04/2023 2:48 pm
