Temp alarm after upgrade to 3.12
Bigjohn
(@bigjohn)
I upgraded my MK3S to firmware 3.12.2. Now every time I try to print, I am getting thermal alarm. Temps look correct on info panel. How can I turn this off?
Big John
Opublikowany : 21/04/2023 9:13 pm
Walter Layher
(@walter-layher)
RE: Temp alarm after upgrade to 3.12
There is a new item in the menu: calibrate thermal model (or something like that, google it and you will probably learn more). Perform this calibration and the alarm will go away. If you look in the forum you will find that people have run into other problems with this firmware. It is not compatible with Revo hotends, some people have crashes during their print when the printer was running fine before and for a long time. Perhaps consider going back to your last firmware.
Opublikowany : 21/04/2023 9:24 pm
