Recv: Error:Line Number is not Last Line Number+1, Last Line: 3861
[Risolto] Recv: Error:Line Number is not Last Line Number+1, Last Line: 3861
Jens
 Jens
(@jens-3)
Hello,
since the update to the new Firmware and an update on Octoprint I cannot finish a singe print. After some 19'000 to 28' gcode commands the Printer demands:
Send: N28750 G1 X121.68 Y83.418 E1.27441*101
Recv: Resend: 3862
It is always the same line nr. requested. Witch is answered by octroprint with:
Should resend line 3862 but no sufficient history is available, can't resend
Changing monitoring state from "Printing" to "Error"
Send: M112
Send: N28751 M112*40
Send: N28752 M104 T0 S0*43
Send: N28753 M140 S0*110
Changing monitoring state from "Error" to "Offline after error"
Connection closed, closing down monitor
Closing down send loop
I have updated the to 3.12.2. However with 3.11.0 I had the same Problem. Has anybody an idea were this could cone from and what I can do about this?
MKS3+
Octoprint Version 0.18.0, running on Raspberry Pi 3 Model B Rev 1.2
Thank in advance for your Feedback.
Kind regards
Jens
Best Answer by Jens:
Hello,
now I downgraded the firmware to prusa3d_fw_MK3S_MK3S+_3_10_1_4697. That has done the trick.
However I have to get rid of the firmware upgrade message at boot up. At least the printer prints again.
regards
Jens
Postato : 02/04/2023 8:38 pm
Jens
 Jens
(@jens-3)
RE: Recv: Error:Line Number is not Last Line Number+1, Last Line: 3861
Hello,
regards
Jens
Postato : 05/04/2023 7:32 pm
Pierre-Yves
(@pierre-yves)
I had the same problem (FW update message). Just comment out the M115 from the start Gcode.
Postato : 10/04/2023 7:52 am
Jens
 Jens
(@jens-3)
Thanks Pierre.
Postato : 12/04/2023 4:40 pm
