Hotend/heat sink slipping downward.
Mehari
(@mehari)
Miembro
I have an i3 Mk3S with a total of over 63 days of relatively trouble-free use accumulated so far.
A couple of months ago I found that the nozzle of my printer had dug into the steel sheet during the early stages of a print, resulting in permanent damage to the sheet. It turned out that the whole hotend/heat sink assembly had slipped downward slightly and increased the nozzle-PINDA sensor offset by a millimetre or so. I disassembled the extruder enough to reposition the heat sink and retightened everything. After re-calibration, all worked well again.
Today the same thing happened a second time. I have repositioned the hotend assembly and recalibrated once more and although all is working well at the moment I am concerned that the fix is not permanent.
Is there a simple solution to this issue or is it necessary to replace some parts in order to prevent it happening in future?  If so, which parts?
Este debate ha sido modificado el hace 3 years por Mehari
Respondido : 26/06/2023 4:17 am
