Error code 2 when exporting a post-processed file?
0mib
 0mib
(@0mib)
I'm trying to test out the arc overhang printing technique pioneered by Steve(?) and Nicolai, source and instructions : https://github.com/nicolai-wachenschwan/arc-overhang-prusaslicer-integration.
The slicing seems to go fine but when I export I get
Prusaslicer has encountered an Error.
Post processing script <path to Python> <Path to script> on file <Path to a temp file?> failed. Error code 2.
I tried to follow the directions but don't do any python so I can't really say much about the code. any suggestions, or clue as to what an error code 2 is when exporting? I'll check the discord for the fork but thought I'd ask here about what exactly the error '2' refers to in case it's something simple like my pathing...
Opublikowany : 23/04/2023 3:49 pm
Hello
(@hello)
RE: Error code 2 when exporting a post-processed file?
Reinstall latest version of slicer after deleting app data file that should repath everything and install python ide just Incase it looks for it
Opublikowany : 24/04/2023 8:56 am
