Parts on Prusa Mini?
JustJay
(@justjay)
Can print the parts on a Prusa Mini or do I need to use a MK3S?
Be bold. Be brave. Be better.
Opublikowany : 29/09/2023 6:58 am
K7ZPJ
(@k7zpj)
RE: Parts on Prusa Mini?
You can print the MK4 parts on the mini if you don't mind having to slice all of the STL files yourself.
You won't be able to print the PG-assembly-adapter on the mini.   Due to the tolerances required by the adapter, a printer specific STL file must be used to print it.   There are only STL files for the MK3S+ and the MK4.
I would recommend using the pre-sliced gcode and print on your MK3.
Opublikowany : 29/09/2023 3:10 pm
