Bed Adhesion Issues After Upgrade to 3.9
Chris
(@chris-57)
Miembro
Ever since upgrading to the 3.9 I have had bed adhesion issues. Smooth or textured sheet it doesn't matter. Material doesn't matter. I've been printing for years and I know the things to do to the print sheet to clean it.
Printed all of the upgrade parts just fine. Made the upgrade and it's hit or miss if a print will stick now. I've made sure the surface of the nozzle is clean by getting it up to temp and using a brush clean it off in case left over residue is keeping the auto Z from getting close enough.
I'm using the Obsidian hardened nozzle, a silicone sock and an enclosure.
Any ideas?
Respondido : 10/03/2024 3:26 pm
Chris
(@chris-57)
Miembro
RE: Bed Adhesion Issues After Upgrade to 3.9
Ok I think I have solved it. After the initial build everything checked out fine in the system tests. After a week or so in the enclosure I think the heat caused belts and hardware to loosen. The Y belt especially. It was failing the Y belt test and sometimes the X. After  re-tensioning the belts and hardware no more adhesion issues *knock on wood*
Respondido : 13/03/2024 3:46 pm
1 les gusta
