Sahde some Light on Bed Level Correction
Dear all - I do a First Layer customization and found -0,73mm is working well for my printer. When I use the automatic bed-level function. The test print with the Bed level test fails. My way to make it work is, to create a 3d-scan of the bed, aligning the scan in a way that the area where the First Layer customization good is aligned to Z=0.
Next, I do a false color plot and measure the distance at 4 points front, back, left, and right. These values are stored in the bed level correction. After this, the printer is working fine.
Any suggestions why the automatic leveling does not work?
Opublikowany : 09/08/2023 4:59 pm
