Random Extruder Skipping Issue
mgtarallo
(@mgtarallo)
Hi guys
After many successful prints, maintenance and calibrations - I just started to experience a random extruder skipping issue with the same model I have been using successfully. . The print and same type of filament used has worked well for 100s of prints - but all of a sudden just stated started to skip in the same spot on the first layer. (I checked for tangle filament as well and I cheeked the idler screw tension.)  I started over and it happened again, in the same spot. I unloaded, did a cold pull thinking it was a clog and it happened again!?!? I unloaded again and this time tried a different filament and it seems to be OK at the moment.  I took the suspect filament and started the print on another Prusa mk3s that I have and so far so good.
I checked the tension and gears in the extrduer assembly and all looked good.
If a part is failing - should I just replace the entire thing? Anyone else experience this and or can provide some advice?
I read some posts on the forums but they didn't really indicate the same issue. (motor temp feels just like my other Prusa printers when printing - so I am not concerned about heat creep - I read something that the motor temp could lower the hotend temp etc)
Regards
This topic was modified před 3 years by mgtarallo
Napsal : 01/09/2023 2:58 pm
mgtarallo
(@mgtarallo)
Update - unknown?
So not sure what it was - hence why I posted it here hoping someone else might have experienced this. I finished a 10hr print overnight with no issue using a different filament and started a new print and it seems to be working fine. I am not sure if it was the tension, a jam etc.
Napsal : 02/09/2023 9:34 am
