Bad print quality
ceesse
(@ceesse)
Bad print quality
I just finished upgrading my MK3S+ to MK3.9 the other day, but I encounter problems with the print quality. There is a lot of stringing and the layers do not seem to be regular.
I have same results with all filaments I tried (Prusament, eSun, Spectrum). I increased the value of retraction (as far as 2mm), but no improvement.
The only thing that seemed to help has been reducing the nozzle temperature to about 180 degrees, but even then it was far from perfect and I started getting nozzle cleaning issues.
I have no clue on what I could try next.
Postato : 04/11/2023 11:49 am
Paco hanno apprezzato
Lemairo
(@lemairo)
RE: Bad print quality
I have the same problem and nothing work, i print with a MK3S+ the same object and i have no problem but with the MK3.9 it's a disaster
Postato : 18/11/2023 6:47 pm
addictedtoslurm
(@addictedtoslurm)
Utenti
After building my MK3.9 kit, I had a similar problem with really bad stringing when I used the default temps for PLA and PETG in PrusaSlicer. If I lowered the temps from PLA from 215 to 180, my stringing went away. I contacted Prusa support and they determined that my hotend thermistor needed to be replaced. My original hotend thermistor was all black. The new one they sent me has half blue wires and half black wires (see the Prusa eshop for a picture). There is a thread on the MK4 forum on this issue. This replacement part fixed my problem and now my prints are perfect. Hope that helps.
Questo post è stato modificato 11 months fa 2 tempo da addictedtoslurm
Postato : 22/12/2023 2:50 am
nhand42 hanno apprezzato
Utenti
Posted by: @addictedtoslurm
Concur.  I had a similar problem.  This needs a store chat report for assistance.
Postato : 22/12/2023 11:27 am
