Print settings for a 0.6mm on MK2S
When you have a 0.4mm nozzle you have 7 options in PrusaSlicer for print layer thickness and quality. I switched to 0.6mm and now have 3: 0.15 Optimal, 0.2 Normal and 0.35 Fast. I'm not sure why those were chose, not saying they were bad choices. What if I wanted to print at 0.4mm, what is that process, do I take the 0.35 profile and change layer height to 0.4? Or does it not matter because I need to change so many? Where do I begin to dial in other layer heights?
Publié : 09/02/2024 1:35 am
