Extruder upgrades similar to MK3/3S?
Bytor
(@bytor)
I currently have stock MK2S and MK2S/MMUv1 printers and I was wondering if there are any official or highly rated upgrades to the MKS2 extruders or other components? For example the MK3 extruder had some changes to improve cooling and reduce heat creep...
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Opublikowany : 20/02/2019 7:48 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Extruder upgrades similar to MK3/3S?
Not a good example. This was caused by a poor fan choice (Noctua), which the Mk2 does not suffer from.
Peter
Opublikowany : 20/02/2019 7:57 pm
Nikolai
(@nikolai)
Based on my experience, if you have no issues with your printer and don't miss any features don't upgrade it. It applies to hardware and software.
In the last two years there were no security or safety features updates for MK2/MK3 series 😉
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 20/02/2019 8:09 pm
Bytor
(@bytor)
Well, I haven't had any problems with the MMUv1 yet, that weren't caused by me, but I also have not been printing anything large and/or complicated.
I have read posts about people making changes to the multiplexer, to the fan duct, etc. However, I haven't seen much in the way of users migrating to those types of mods.
Once I finish the current project (making drink coasters with the company logo, website, etc.) I was going to give a shot at printing some of our equipment and using BVOH supports (at the interface). When I printed on piece of equipment with our MK2S it was about 50 hour job and removing the supports was a pain. So, in a way I was hoping there were some tried and true mods that would, potentially, help the print not fail.
- 3rd PRUSA i3 MK2S
Opublikowany : 22/02/2019 7:10 pm
Hughe
(@hughe)
I replaced the stock extruder with Bondtech dual drive system to increase printing speed on Volcano Hotend.
Bondtech dual drive provides steady, consistent extrusion. Changing filament is quick and easy compared to the stock one.
I had to reduce extrusion multiplier from 1.174 to 0.83 on Slic3r. Printing speed doubled without any retraction issue, which I was expecting to see.
https://www.thingiverse.com/thing:3562627
I'm installing MK2.5S extruder on a MK2S machine. MK2.5S's extruder is way more complex than Bondtech.
Opublikowany : 18/04/2019 7:16 am
danielkrah
(@danielkrah)
RE: Extruder upgrades similar to MK3/3S?
https://www.prusaprinters.org/prints/3813-prusa-mk3-fan-on-mk2s-mount
i made a replacement part so you can use the MK3s fan shroud on a MK2(s)
Opublikowany : 06/09/2019 10:33 pm
