Bad quality on Prusa i3 MK2
josh.r7
(@josh-r7)
I am having a couple of problems with my Prusa i3 MK2. It appears that most prints have some weird lines. I printed the rectangle at 200 microns, about 15mm/s or less with PLA and 100% fan speed, hot end at 190C. Marvin had the same problem but it has been printed with the file from the included SD card (marvin printed at 100 microns).
I already contacted support but this was their message:
Hello Max,
Since you’re using S3D, which is a problem child for us at PRUSA and not a fully supported slicer, I’d like to know if you’ve had similar issues with the factory prints (and if you can share photos of these for reference. Since you were able to calibrate I assume they are somewhat more successful?
https://radrdetector.com/best-radar-detector-reviews/
https://wanderviews.net/best-trail-camera/
https://wanderviews.net/best-front-and-rear-dash-cams/
http://iapkdownload.com/live-lounge-apk/
https://www.techtrickhub.com/fortcraft-apk-download/
Publié : 21/10/2018 12:56 pm
gary.b
(@gary-b)
Re: Bad quality on Prusa i3 MK2
Josh.r7, this is not the correct heading for your MK2 printer problem. You would be better served to post questions in the Original Prusa i3 MK2/S section.
MK2S & Mk3 my mini farm is alive 😆
Publié : 21/10/2018 5:19 pm
