Z-hop limited above 1mm?
Looking into default profiles for Slic3r I found out that Z-hop (Lift Z) is limited to layers above 1mm. Does anybody know the reason?
Opublikowany : 28/07/2016 5:47 pm
Re: Z-hop limited above 1mm?
No, but I use it on the first layer (when I need it) so I don't knock anything over.
This is with KISS.
Peter
Opublikowany : 28/07/2016 7:12 pm
