Z Endstop Wiring Issue
jameson.w2
(@jameson-w2)
I am having an occurring issue where I fail the selftest during the Z endstop check. I was somehow able to get it to work and was able to print the batman symbol but now the issue has returned. I cannot calibrate the Z-axis because of this and from there I can't do anything. Could the probe or board be damaged? Please help.
Postato : 09/06/2016 7:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Z Endstop Wiring Issue
Most like the RAMBo connector is not homed or one of the sires has come adrift inside the connector.
Take the connector out, check that all 3 pins are fully inserted into the plastic connector housing and plus back into the RAMBo. Ensure you get the "click".
Peter
Postato : 09/06/2016 10:13 pm
jameson.w2
(@jameson-w2)
Thanks for the advice, Peter. However, it did not work. 🙁
I made sure the pins were attached and touching the ones on the board and still nothing.
Is there anything else I can try short of buying a new probe?
Jameson
Postato : 10/06/2016 12:33 am
PJR
 PJR
(@pjr)
Contact support - use the "Live Chat" facility on the shop pages, advise them you have a failed self-test and give them a link to this thread.
Peter
Postato : 10/06/2016 8:45 am
