Z Calibration Crashing Into The Bed At Middle/Right Point
IdolCrasher
(@idolcrasher)
Hi guys. Up until now, my prusa has been working fine. My Prusa Nozzel just started crashing into the bed during the z calibration.
It makes it through the first front 3 points, but then crashes on the right/middle dot. The area is clean. I even removed the PEI thinking maybe it was the problem.
I am really stuck. Any thoughts?
Publié : 23/05/2017 4:16 pm
IdolCrasher
(@idolcrasher)
Re: Z Calibration Crashing Into The Bed At Middle/Right Point
I'm having a tough time guys. I just had to replace my x-belt that stretched on me too. I couldn't believe the an "original prusa" part would fail on me like that.
Now I can't do the z calibration 😯
Publié : 23/05/2017 4:21 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
If there is no plastic stuck to the nozzle, lower the probe slightly and retry. You will have to readjust you "Live Z"
Peter
Publié : 23/05/2017 4:29 pm
jesse.s3
(@jesse-s3)
This is the exact point my printer just crashed into this morning. Middle calibration right side. It's been good until now. It damaged the bed slightly but may be OK. Did you figure out the problem? My sensor is set to the right height but maybe lowering it a tab could help.
Publié : 25/05/2017 3:42 pm
PJR
 PJR
(@pjr)
It's the same on my 2 printers; the probe response is lower on the right points than all the others, probably because of the frame and/or psu.
Just lowering the probe very slightly will resolve the issue.
Peter
Publié : 25/05/2017 5:48 pm
