Y-motor holder wrong diameter of holes
Anyone having the same issue in MK2 kit? Mine was prepared on Dec 27th (order 2016215344).
The nuts diameter is M8 and the hole is around 6.5 mm. I checked the y-motor.stl file which seems correct. I checked also if it can come from an old prusa model, but it's a different shape.
On the picture, you can see the wrong part beside the Y-idler which is correct.
Opublikowany : 04/01/2017 11:08 am
Re: Y-motor holder wrong diameter of holes
That does look wrong...
I would contact the Prusa live chat team and direct them to look at this thread to see the problem.
Opublikowany : 04/01/2017 1:02 pm
