XYZ Calibration poking holes in bed
mathieu.n
(@mathieu-n)
I thought I was done with issues after experiencing some level of reprieve but alas, this was short lived.
My MK2 runs 3.0.9. After deciding to do a routine calibration this morning, when moving to calibration point 4 (right center point), the printer went and pushed down the bed and then proceeded to scratch the film severely (pictures attached). I noticed it did the same thing with the very center point of the bed which I think is point 5 thus it would appear it starts doing this when it moves to the center row of calibration points.
I'm at a complete loss. Find attached a bunch of pictures depicting the various components and the damage. I'm certainly desperately in search of some form of explanation since I can't auto calibrate anymore.
Opublikowany : 01/03/2017 4:34 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: XYZ Calibration poking holes in bed
pretty sure i've seen this picture before. you are not the first one with this problem.
but i think they've done something against it in the latest firmware (3.0.10).
Opublikowany : 01/03/2017 4:39 pm
mathieu.n
(@mathieu-n)
Upgraded firmware and also lowered PINDA even further, about 1mm offset from nozzle tip. It finally calibrated successfully with no report of axis skew this time!
Thanks!
Mat
Opublikowany : 01/03/2017 7:24 pm
