XY calibration worsening orientation of points 1 & 9
Rutilate
(@rutilate)
My PINDA placement and bed orientation is worse after running the 3.0.5 xy calibration.
Before running the xy calibration (or after resetting), the PINDA probe is perfectly centered in points 1&9 in the y direction, and just barely outside the right edge of both the 1&9 points (eh. pics uploaded from phone are upside down. So stand on your head!).
Runnning the xy calibration, I get the message that the XY is perpendicular. However, for both positions 1&9, the PINDA probe is now centered in X but well forward and out of the circle in Y.
That doesn't seem like expected behavior.
First question: why is the PINDA probe to the right of the circle? Is that a problem with needing to add a small strip to the part of the extruder body that hits the x end-stop? I've tried to move the end-stop over as far to the right as possible and can't get it any further.
Second question: If the xy calibration finds that my bed is perpendicular (which I painstakingly ensured by measuring diagonally and adjusting when rebuilding), would it be better not to do the xy calibration if it is going to erroneously reposition the PINDA probe?
Respondido : 17/07/2016 12:39 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: XY calibration worsening orientation of points 1 & 9
Curtis
1. Yes
2. You are not alone with this issue. This morning, just uploaded the 3.0.5RC firmware; "axes are perpendicular", but as with 3.0.4 beta, the points are now not in the circles. I presume that the inserts in the bed may not be positioned as accurately as the should be.
Peter
Respondido : 17/07/2016 11:52 am
Rutilate
(@rutilate)
Curtis
1. Yes
Peter
Thanks, Peter. I thought for sure I was going crazy. Glad to hear that I'm not the only one, and looking forward to an updated firmware.
Respondido : 18/07/2016 1:55 am
Rutilate
(@rutilate)
I've just upgraded to 3.0.6RC and the problem still exists. I have adjusted the bed so it is perfectly centered in the 1 & 9 calibration points but after doing the XY Calibration the PINDA probe is sitting on the border, just as shown in the pictures above.
Is anyone else seeing this?
Respondido : 31/07/2016 8:32 pm
Vojtěch Bubník
(@vojtech-bubnik)
Miembro Admin
Curtis,
today I discussed a similar issue with another customer. On his printer the XY calibration failed with an error message. The cause was a slipping Y pulley.
I have a feeling this may be your case as well. The XY calibration pushes the table to the Y end stop repeatedly and the calibration procedure exercises the X and Y axes quite a lot. If either the X or Y pulley slips, the measurements the XY calibration procedure makes are skewed. In your case it seems to me that the Y pulley slips or the Y motor skips steps before the calibration routine starts, which then shifts all the measurements in the Y direction.
I shall update the XY calibration routine to verify at the end of the calibration routine, that the printer reads the expected X/Y coordinates when the X/Y end stops are reached. This procedure would verify for both the skipped steps and slipping pulleys.
Vojtech
Respondido : 31/07/2016 10:35 pm
Rutilate
(@rutilate)
Curtis,
Vojtech
Vojtech, thanks for the diagnostic pointer. I'm in the middle of a long project right now but immediately afterwards will tighten the Y pulley and belt.
Respondido : 01/08/2016 1:48 am
