X axle problem - too wide prints
piotr.s
(@piotr-s)
hello,
This is my first post on this forum, so please excuse my possible errors.
I'm using Prusa i3 MK2 for about 3 months, but from about few days I have problem with X axle - every print is about 1-2mm wider than set up.
I tried circles and squares - every is on the X axle wider. The prints weren't detach from bed, looks also very ok, only have issue with the X dimensions.
I upgraded firmware more that month ago, this problem appeared few days ago, so I assume that this is not firmware issue, but maybe?
I found that someone has similar problem with Z axle, then it was issue with the motor...
Would appreciate some advice.
Publié : 24/03/2017 12:13 pm
piotr.s
(@piotr-s)
Re: X axle problem - too wide prints
I made some tests and the result if them is that the sli3er (also newest) have this problem.
When I print the same STL model in Cura I have no issues with the dimensions.
Publié : 28/03/2017 11:32 am
