X-Axis Grinding during calibration
David Anderson
(@david-anderson-2)
Hello. I have finished assembling my printer and XYZ calibration works perfectly. I then go to print V2Calibration.gcode. I adjust the z-height to get the proper height from the bed. When I then go to print anything else, it does the first 4 calibration points, then makes an awful grinding noise and seems to seize up on the x-axis moving to the 5th calibration point. It stops 2/3 of the way to the calibration points and probes the bed and fails. Any ideas what might be happening?
Opublikowany : 09/02/2017 3:22 am
David Anderson
(@david-anderson-2)
Re: X-Axis Grinding during calibration
Resolved my problem. Solution for anyone who finds this. I loosened the X-Axis belt one tooth and it is working now.
Opublikowany : 09/02/2017 5:09 am
