Wrong Power Supply Voltage
yosmar.p
(@yosmar-p)
Hi, I am new here, and I just got my Mk2S assembled. Maybe I was too excited to turn it on for the first time, somehow I forgot to check the input voltage switch. It was on 110V, while the power supply I have is 220V. So,,, I might have broken some things inside 🙁
Can anyone guide me which part most probably got damaged because of this?
Publié : 21/11/2017 4:48 am
surfgeorge
(@surfgeorge)
Re: Wrong Power Supply Voltage
Sounds like you shot the power supply.
I suppose you already tried switching it to 220 and it didn't work.
Most likely you will only have to get a new power supply, but I am sure you are not the first one to have this happen, so contact Prusa support and ask them what parts you need to replace,
Sh*t happens, but this one can be fixed! 😉
Publié : 21/11/2017 9:49 am
yosmar.p
(@yosmar-p)
It's just like what you said, I already tried switching it to 220 and it didn't work.
But, there is the good news. I tried to open the power supply and actually I found out that the first fuse was blown (there are 2 fuses in PSU), so I replace the broken fuse, and all work well !
I even managed to print several 3D parts already and having fun with it 🙂
Thanks for the advice and all. I will just post this here so maybe if someone did same mistake as I did, they can try this solution 😉
Publié : 21/11/2017 4:08 pm
