Why is my castle not sticking to the bed
kvangrieken
(@kvangrieken)
Printer runs and prints amazing.
Problem I am having is when I print the castle. For some reason the sides lift up and won't stick to the bed.
Could my PEI on the bed neeed replacement?
I tried 2 times, once with out glue and once with the glue stick and the results are the same.
Postato : 21/05/2017 3:13 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: Why is my castle not sticking to the bed
if you've found the correct value for the z-live adjustment, you don't need any glue or other sticky stuff, at least for pla, woodfill or petg, if your pei sheet is cleaned properly (personally i recommend 99% ipa and after every fifth print pure acetone) !
Postato : 21/05/2017 6:43 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
You may find that increasing the bed temp by 5 degrees may help.
Peter
Postato : 22/05/2017 9:52 am
