which slic3r version for single extruder ?
cyrille.p
(@cyrille-p)
I'm using slic3r 1.34.1, i've got an mk2 with a single extruder. It seems to me that versions above 1.34.1 are for the multimaterial but I'm not sure. I wonder if I can use the latest version with my single extruder or just stick with my 1.34.1 (which works perfectly for me 😀 )
My youtube channel about the Prusa I3 MK2 https://www.youtube.com/channel/UCz-zQZcKcvEDdd9C9hOKYWg
Respondido : 26/07/2017 4:48 pm
henrik.w
(@henrik-w)
Re: which slic3r version for single extruder ?
Hello Cyrille!
I think you can use later versions of Slic3er as well as the version you are using now. I do not see why it would take a different slicer for different versions of the Prusa.
/Henrik
Respondido : 01/09/2017 2:59 pm
AJS
 AJS
(@ajs)
The newer versions of Slic3r support both single and MMUs.
You load the different .ini files to select functionality.
Respondido : 01/09/2017 4:24 pm
