where can I download the Files on SD card
cnever
(@cnever)
Hi
My sd card just decided to die and I did not backup the files. Is there a spot with these files that I can download? Like a standard zip file with all the test models and v2 calibartion?
Thanks
Postato : 12/03/2017 11:09 am
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: where can I download the Files on SD card
Hi
Thanks
💡 just install the full driver package. you'll get a 3D Objects folder after the installation at your program start menue. there you'll find all the genuine files initially provided through the sd-card.
ps. personally i would recommend the following when you have problems to get live z adjustment right with the genuine v2calibration.gcode. you can use it instead of the v2calibration file.
Postato : 12/03/2017 2:28 pm
cnever
(@cnever)
Thanks for the tip !
Postato : 02/04/2017 11:21 pm
