What Gcode is senden when you abort a print (SD)
Foxen
(@foxen)
Hi guys,
I wanted to know what gcode is sended when you abort a print via the lcd display (print from sd card).
Using the latest 3.1.0 firmware on an MK2.
The Nozzle lifts up and the bed comes forth. I want to know the gcode for that. I am mainly using Octoprint so I want to add the gcode for abort a print there
many thanks
Sven
Veröffentlicht : 18/02/2018 6:55 pm
supermerill
(@supermerill)
Re: What Gcode is senden when you abort a print (SD)
It send nothing, it just stop reading and do dome hard-coded stuff.
What you want (nozzle lift up, bed advance):
To move the head up 2mm, write
G91
G1 Z2.00 F7200.000
G90
To move the bed in the front, write
G0 Y210.0 F7200.000
To "abord" a print, just write nothing after that point.
source : http://reprap.org/wiki/G-code
Veröffentlicht : 19/02/2018 6:18 pm
