What could be causing this pattern on the z-axis?
duncan.b2
(@duncan-b2)
Hello everyone, I'm new to the forum and have been enjoying my MK2 for hundreds of hours. Recently i have noticed really bad layer quality and wanted to ask for help. I ran the hotend at temps from 200 to 235 and the z pattern is still prevalent. It almost looks like z wobble except it happens at much greater frequency compared to the pitch of the lead screw. Some of my other prints are showing under extrusion and I was curious if under extrusion could be causing the defect. If not, then what is causing it?
I don't seem able to add attachments. How can I share pictures on this forum?
Thank you!
Napsal : 03/11/2017 11:15 pm
samling
(@samling)
Re: What could be causing this pattern on the z-axis?
I think you need to make a few more posts before you can attach pictures (I think 3?), but you can also upload them to a site like imgur.com and attach them using the "Img" button above the text field when making a post. Definitely will need to see photos of what you're talking about to offer any help.
Napsal : 04/11/2017 9:05 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Just create a new post and drag an image file onto the test box.
Peter
Napsal : 04/11/2017 10:22 am
duncan.b2
(@duncan-b2)
Thanks for the quick reply! I have attached a photo that has the defect in question encircled. Of note is that the same gcode was ran a week earlier without the print showing this defect. Thank you again!
Napsal : 06/11/2017 4:57 pm
