What causes this (misaligned layers)?
aric.e
(@aric-e)
I printed the exact same G-code 3 times. See the attached image for the three different results. The misalignment is in the Y-axis.
The prints were done in PLA with default Cura Normal Quality, however I've experienced the same phenomenon randomly with the Prusa Slic3r on other files.
Thanks in advance!
Opublikowany : 25/04/2017 6:53 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: What causes this (misaligned layers)?
A few things:
The pulley is too close to the motor
The pulley grub screw is loose
The belt is loose (slipping)
Printing in "quiet" mode
Plus a few other less likely things.
Peter
Opublikowany : 25/04/2017 6:56 pm
michael.e3
(@michael-e3)
My guess would be a very loose belt, or the motor gear loose.
Opublikowany : 26/04/2017 12:45 am
aric.e
(@aric-e)
Tightened the y-axis belt and haven't seen it since. Thanks!!!
Opublikowany : 02/05/2017 5:07 pm
