Warping on my print
jerome.k
(@jerome-k)
Warping on my print
I have warping on my print and tried different settings without success.
In the Attach you can find the .stl the .gcode
Thanks for your help.
Jerome
Respondido : 06/12/2016 3:43 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Warping on my print
Increase bed temp; print with a brim
Peter
Respondido : 06/12/2016 3:51 pm
mavu
 mavu
(@mavu)
What material did you use?
jerome.k
(@jerome-k)
Ok i will try.
Printing with PLA
Respondido : 06/12/2016 4:02 pm
PJR
 PJR
(@pjr)
Printing with PLA
That's what the files say...
Peter
Respondido : 06/12/2016 4:36 pm
jerome.k
(@jerome-k)
Thanks for the quick help.
Bed Temp 75°C for first Layer, then 65°C
Brim 4mm
No more warping.
Respondido : 06/12/2016 5:36 pm
PJR
 PJR
(@pjr)
Jerome
75 is a little too warm for PLA. Glass transition temp in the early 60's.
Unless your bed is not reaching the recorded temp (ie thermistor issue), you may want to turn it down a tad.
I always use 60 degrees, unless I'm printing a large object, where I push to 65. I do print the first layer at 215 then reduce by 5 to 15 degrees depending on print speed.
Lowering Live Z adjust may also help.
Peter
Respondido : 06/12/2016 6:04 pm
