Visualizing the XY axis
Shree Kumar
(@shree-kumar)
Since I got the MK2, I've been thinking of good ways to estimate the accuracy of calibration.
I have printed as many as seven one cm side cubes. I am not very convinced by the results on that - my measuring instruments are inexpensive, and don't provide very consistent results. What if I could use the grid on the bed itself to reveal the problems ?
A few days back, I hit upon the idea of drawing the grid lines. I wrote an OpenSCAD script for this. The zip attachment contains a the script, STL model, and gcode (for PLA at 210 degrees, 0.2 mm layers sliced using Slic3r).
It takes about 10 minutes to print at default settings. I printed with red filament, then with white filament for better contrast on the heat bed. Then photographed the bed with a tripod mounted camera. The high resolution picture (24 MP in my case) captures the slightest misalignment easily. I have attached the high-res image to this post.
Clearly my XY is off by a bit. But there other interesting jumps happening at Y=105 and Y=55. I haven't been able to explain them yet.
Napsal : 05/07/2016 8:37 am
David T.
(@david-t)
Re: Visualizing the XY axis
I guess loose screws in X-motor pulley. If it is loose only little bit, it causes shifts in X dependent on actual direction of drawing moves.
Napsal : 05/07/2016 10:05 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Be careful when relying on the lines printed on the bed; some of the lines on my bed are not straight when the bed is hot.
I found this out when eyeing up the frame to check it was square; a couple of lines were OK in the centre but bent forward at the ends.
Peter
Napsal : 05/07/2016 10:27 am
Shree Kumar
(@shree-kumar)
I will check this. Thanks for the hint.
I will check the lines a combination square. Just to confirm : Are you saying that the lines are straight when cold and that they bend when the bed becomes hot ? That will be interesting.
Napsal : 05/07/2016 11:07 am
Shree Kumar
(@shree-kumar)
(Updating here after a long time.)
I was able to debug and fix the X axis "jumps" at Y=105 and Y=55. I figured the belt was going over the pulley & causing a slight X axis jump. Due to this, the head wasn't able to reach X=250 smoothly.
I trimmed a cm or so off the the X axis timing belt on the right side of the extruder - and that fixed it... The grid printed by my MK2 is now smooth & square, and without discontinuities.
Napsal : 16/08/2016 1:46 pm
