Vertical lines. Uniform banding
chris.b
(@chris-b)
I've been working on my mk1 to mk2 upgrade. I had issues with calibration and the frame not being square but was finally able to get through calibration successfully and the remaining calibration steps. When using simplify3d (Prusa forum downloaded rec settings) I am getting an even vertical line pattern (almost even). Not real sure what the problem is and I know I need to do some more testing and prints. I am thinking my extruder idler screws are too tight. The pattern is quite uniform as u can see by the photo.
I printed some 40mm squares (not a perfect square as the ht is not 40mm) at three different resolutions 0.2, 0.1, 0.05--again using prusa forum settings that are available for download.
Any comments or thoughts would greatly be appreciated. Thank you in advance.
Opublikowany : 26/09/2016 8:54 pm
David T.
(@david-t)
Re: Vertical lines. Uniform banding
Please do at least basic search in this forum before starting new topic to avoid duplicates.
http://shop.prusa3d.com/forum/viewtopic.php?f=6&t=1279
Opublikowany : 26/09/2016 10:54 pm
chris.b
(@chris-b)
I did read through those posts--banding looks a bit different than the type demonstrated in that post-- if you look at the examples. So I posted separate.
Opublikowany : 26/09/2016 11:08 pm
