Unload filament - Issue
Hello
It is already 3rd time, just wonder why it happens!
How it happens
1. Preheat PLA or already preheated
2. Unload filament
3. when extruder stops i pulled up filament and some part of filament (in shape of drop) stays in teflon tube
4. If i load new filament it goes inside and push that "drop" trough tube to hotted and then stuck in the end of tube ( why in the end - i have found it when disassemble extruder)
5. It is very annoying disassembling extruder every time changing filament 😳
Just wonder why, and what i do wrong while unloading filament.
Thank you!
Re: Unload filament - Issue
I unload filament at 170°C and only then (before loading new filament) preheat to filament target temperature. I did that countless times on MK2 and never got anything stuck in extruder.
There are occasions I use "Cleaning" filament to push through bad filament left behind when I unload filament and for when I want to change to a different filament. I've had no real problems with having to break open my hotend to clear a clog because of this. I did get a clog last night, but my cleaning filament was able to fix it.
I've been using your method lately and works like a charm. Much cleaner unloads.
Thanks!
😉 Thank you guys, will use this method next time!
The only problem of this method is you can't use it during printing. You can evade that by playing with temperature around M600 gcode command - bring it down a bit before M600 and bring it back after finished M600.
