Unload filament command works below safe temperature to unload filament, now filament is stuck
Hi all
I accidentally asked the printer to unload the filament while the hot end was still warming up (I think around 120 degrees C) and it got half way and got stuck. I know there is probably a reason that it lets you unload filament while the hot end is still cold but it would be useful if there was a prompt to say 'hot end is below safe unload temperature do you want to proceed unloading filament?' before letting you do it.
Also how do I get it unstuck? It won't load or unload despite being at temperature now.
I'm using firmware 3.0.8
Thanks very much
John
NOTE: Topic moved to English forum (PJR)
Posted : 17/11/2016 2:31 pm
