THIN EDGE ON PERIMETER
michael.l32
(@michael-l32)
Wondering if anyone can help...
I just got the MK2s. All my prints have a very thin edge on perimeter of first layer. Can you tell me how to correct this? I tried reducing bed temp by 10 degrees, but did not help. I get this protrusion when printing either PLA or PET. Brim and Raft are off.
Thank you,
Mike
Postato : 15/07/2017 2:52 am
aaron.s5
(@aaron-s5)
Re: THIN EDGE ON PERIMETER
If your Live Adjust Z level is set too low, it will squish the first layer making it wider than it should be. See "Life Adjust Z - my way" thread.
How big is that little edge? Less than a mm? Picture?
Calibrating the extruder might help too.
Postato : 15/07/2017 3:50 am
michael.l32
(@michael-l32)
Protrusion might be 0.1-0.2 mm. I tried raising the Z axis, will raise it some more.
Thank you!
Postato : 15/07/2017 7:48 pm
michael.l32
(@michael-l32)
That corrected the problem.
Thanks again!
Postato : 15/07/2017 9:27 pm
