The print does not adhere to the bed - nozzle damaged the floor
andrea.s4
(@andrea-s4)
I tried to do the test print V2calibration.gcode
but on contact with the printing bed the first filament does not adhere uniformly, and then comes off by itself.
firmware updated
all calibrations results ok
How can I solve?!?
Publié : 05/12/2017 5:49 pm
alexander.s27
(@alexander-s27)
Re: The print does not adhere to the bed - nozzle damaged the floor
You may want to follow this guide or your manual.
http://manual.prusa3d.com/Guide/5.+Preflight+check/334
It is said that once your nozzle touches the bed or even the sheet of paper
you should have placed between nozzle and bed to cancel the process at once pressing reset.
After that you have to move the PINDA sensor somewhat in direction of the bed, yours is way to far from the bed.
Publié : 05/12/2017 6:50 pm
AJS
 AJS
(@ajs)
These steps might help you get a good Live Z adjustment which is critical (and you don't yet have).
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Publié : 06/12/2017 4:05 am
andrea.s4
(@andrea-s4)
In my kit of accessories, I do not have the zip ties. How can I do?
Publié : 06/12/2017 9:34 am
alexander.s27
(@alexander-s27)
In the kit should be a satchel of about 50 or more zip ties.
Take anything what is around the same thicknes 1,5-2mm or do it just without.
The nozzle barely touching the bed, the probe should be moved away from the bed just about the said dimension.
Starting the calibration you will see whether it would need to readjustetd.
No matter whether you use a zip tie or this tool here... https://www.thingiverse.com/thing:1977997
there sometimes is need to adjust it somewhat...
Publié : 07/12/2017 11:47 am
