temperature stops t 150
having a problem with my mk2s
alarm went off then after turning on and off a few times i tried to preheat for pla
temp only went to 153 and stayed there
checked all connections they are fine
updated firmware and printed fine then had power outage
filament was stuck in heat sink so i took it off and cleaned it out
replaced nozzle and put back together
again all wires are connected
getting frustrated because i have taken the heat sink apart( 3 times) and even replaced with a new one because of clogging
only had this for 3 months
Postato : 11/12/2017 8:11 pm
Re: temperature stops t 150
Check wiring again.
Maybe you have exchanges the hotend sensor with the heatbed sensor in the box.
Thomas
Postato : 11/12/2017 8:35 pm
